Re: electronic ignition vs. points & condensor?
Trent, Thanks for helping me. But I CAN'T start the motor.
When I turn the key to the on postition the volts on the gauge is under 10. I have minimal spark coming from the coil and no spark at the end of the plug wires. I have tried to hot wire it with no luck.<br />It is a 1988 24' bayliner trophy, 305 omc cobra. I have replaced the impellar, thermostat, pullies, belts, exhaust manifolds and risers, coil, ignition module, and alternator. I had a overheating problem, fixed that.. Now this, it ran after I changed the ignition module for about 6 hrs on the water, went to start it again and it fired up and sputtered out from sitting all night, started again at 1000 rpm's let it warm up and dropped back the rpms to neutral ran for 15 seconds and died. Now it won't start at all. Stuck on the water again. second time in 3 outings.<br />Should I change it to a points and condensor starter?
What will that do? I am told that will atleast eliminate the thought that it is my ignition module.<br />What do you think?
