quick_claude
- Nov 6, 2001
- 16
This is my first post to this site but I have been a long time reader. My boat has an I/O 1978 120hp MerCrusier (153cc). I ordered an electronic ignition conversion kit with primary coil and distributor. THe new coil has two wires to connect (a purple wire to power and a grey wire to the tach). My old conventional coil has both a power wire AND a resistor wire going to the positive side. The instruction kit said to bypass the resistor wire. My first question is "can I just cut and cap off the resistor wire?" What is the other end of that resistor wire connected to? <br /><br />Also, there were two wires on the negative side of the old coil. One went to a ground on the bell housing. I assume the other was the tach wire. Does both of these wires ground and tach) connect to the grey wire on new coil?<br /><br />All advice will be greatly appreciated.
