Electronic ignition conversion HELP!!!
slimmons1998
I have recently purchased my very first boat, 1983 Glastron SX 190. It has a 3.8L OMC engine with points. I am wanting to convert the points over to electronic ignition. Does anyone have a recommendation or links to a place that sells this? I have searched google and many other places with no luck.
slimmons1998
Re: Electronic ignition conversion HELP!!!
Thanks Butch! I will give them a look. I am new to the boating scene and trying to learn all I can.
Howard Sterndrive
No marine electronic conversion exists for the IBM7014 distributor in your Chevrolet 229 Marine engine (OMC 3.8, Mercruiser MR185V6, VP-AQ175).
You are stuck with points.
Due to the semi-even unique firing pattern of the 229, and phase out in 1985, a marine electronic system was never introduced.
You could put other 6 cyl. Prestolite pertronix kits in (e.g. 4.3), but the firing will be 12 deg advanced on 3 cylinders and 12 deg retarded on the other 3.
Pertronix will custom make you a trigger ring (or they used to), but it's expensive.
If you do go that route, order a half dozen and let me know.... I'd like a couple.
If you must have points, your only off the shelf option is automotive HEI, (1983/84 Malibu, Monte Carlo ElCamino etc with the 229) which is not really safe, nor does it have the right advance curve. It'll run fine, but there's the explosion risk.
Howard Sterndrive
nope, that's for a 4.3 IBM7021 distributor with even firing.
from TDC the spark is distributed as follows on a 4.3:
120, 120, 120, 120 120, 120
your 3.8 has the following firing pattern from TDC:
108, 132, 108, 132, 108, 132
If you look at the tag on your distributor, you will see it is a presolite IBM7014, not listed there for this reason
You can put a 4.3 Pertronix in and the engine will run (and fairly well believe it or not), but it won't be right and you risk detonation damage to three of the 6 pistons.
slimmons1998
This is what I got from PerTronix:
Shane, correct me if I'm wrong but I think you are looking for an Ignitor
points replacement kit. If so, Ignitor kits are distributor specific and I
need you to send me the distributor manufacturer, the number stamped into
the housing, system voltage, and system ground. I will then email you with
the product information you are requesting.
Thanks, PerTronix
Howard Sterndrive
let us know what he says about the IBM7014...ask how much to make a custom trigger pls.
slimmons1998
Shane, do you mean can we make a custom kit for your distributor. The answer in probably yes? We would need you to send the distributor here for evaluation. Typically the cost is $300 to $500.
PerTronix
-----Original Message-----
From: shane simmons [mailto:slimmons1998@yahoo.com]
Sent: Friday, January 22, 2010 11:10 AM
To: Customer Service
Subject: Re: General Website Feedback/Question
Do you make a custom trigger for this?
To: shane simmons <slimmons1998@yahoo.com>
Sent: Fri, January 22, 2010 1:05:47 PM
Subject: RE: General Website Feedback/Question
Shane, I show that distributor as an odd fire distributor which we do not have a kit for.
Sorry, PerTronix
Sent: Friday, January 22, 2010 10:51 AM
IBM7014 ? I think this is correct? 12V system
To: slimmons1998@yahoo.com
Sent: Fri, January 22, 2010 12:47:50 PM
Thanks, PerTronix
From: PerTronix Product Support [mailto:info@pertronix.com]
Jan 22, 2010
Shane Simmons
I have a 1983 Glastron boat with a Chevrolet 229 Marine engine (OMC 3.8,
Mercruiser MR185V6, VP-AQ175). Do you make a HEI conversion kit for this
model?
zbnutcase
$300-$500 wil buy a awful lot of point sets...'nutcase
Howard Sterndrive
for $500, I'd go with a 4BBL and intake. then we're talking money well spent.
Those little 229's love a quadrajet.
get a used marine QJ and freshen it, and a 90deg V6 intake (factory highrise cast 4.3 from an Astrovan).. good for an extra 15 to 20HP
slimmons1998
any links to a place that may have what you are suggesting? I did email a guy named Marvin there and he said it was $350 for a custom setup and 4-6 weeks turn around. I will probably do that just so I dont have to worry about points anymore.
rbh
ask around here to find out who else wants one maybe you can get a bulk discount.:)
windsors03cobra
Wow that scared of points ? Run that bad on points ? Gone run the same with a pertronix. Weird. :redface:
slimmons1998
Not scared of points, just never dealt with them. I remember my dad always messing with them and it seemed like it was a lot of trouble. I did read the guide here on how to set them up so I will try that before I send my distributor in.
TechnicallyReal
I know this is super old but anyone happen to know if any options appeared in the past 14 years? I have two boats with Volvo Penta AQ175 / GM 229 engines and would love to convert them.
Scott06
it is super old you would be better off starting your own thread as the mods will close this one shortly.
If a delco est fits your engine that is best way to go
