I have a 1998 crownline 202br. Has a 350ci alpha outdrive. My issue is key on boat running or not when the radio is on and you hit any other switch; blower, trim, dash or nav lites the radio shuts off for a second then turns back on. Or if blower is running and any other switch is turned on the blower slows down. Are my batteries bad is it a bad ground. Help please!
Under the dash everything is clean. I had the problem last season. I’m in the dewintering phase. The testing today was with motor off
