HighTrim
- Jun 21, 2007
- 10,486
Morning All,
I just installed a new fuel sending unit on my built in tank. I see that the red wire goes directly from the top of the sending unit screw to the sender connector on the gauge. Now the ground wire, does it run off the unit, split, then one end to a ground, and the other to the bulb connector on the guage?? Do I actually screw in a ground somewhere, or tap into an existing ground wire in the area? My directions for this are hazy at best. Also there is a grounding staple on the washer for the sending unit. Does it matter if the flat side of the staple is against the tank or flange of unit? My holes seem to line up better when the flat side of the staple is against the tank, but that way there doesnt seem to be a whole lot of contact against the flange. Ty each and all for your input.
