HighTrim
- Jun 21, 2007
- 10,486
Evening gentlemen....
Took the boat out today and had a couple issues that are new to me. Boat is a 1989 Cadorette 200 Holiday with a Mercruiser 4.3L Alpha One.
There are 2 issues, which I feel may be related. The first is that when plugging in the shore power, it trips the GFI at the plug instantly, meaning to me there is a short to ground somewhere. There is no hot water tank, so that is eliminated. Now, when running the CD player, it will sometimes suddenly power off, causing the voltage meter to peg out at 16 Volts instantly, then when the CD player comes back on, the voltage will go back to a normal 14 Volts. This only happens when the CD player "dies". If I do not turn the CD player on, it charges normally at 14 Volts. Does this sound like a short to ground in the CD player wiring? And if so, any likely spots? Or am I off track here?
