Re: electrical problem
Thanks for reply rodbolt, i have new cdi,manual,dva meter ect. all res tests are good on pluser coil,crank sensor and ign coil. output test on charge coil are funny. with yellow wire unpluged (bypass) i have no change from crank to running i think this is normal because of (bypass). if i plug back in the yellow wire i can not run it to test past 1500 rpm.if it runs in bypass charge coil/ign coil should be ok? two parts left crank sensor and pulser coil.<br />what do you think?
