Electrical problem need help
Fireguy180
Wires cut that went to the trim sensor and it will go down but need to use the trailer button to go up also none of the gauges work or lights horn nothing
wellcraft-classic210
Master Chief Petty Officer
You have a trim SWITCH that is needed for the up ckt to work out of trailer mode and a trim SENSOR on the other side that is associated with the trim gauge ( if you have one ) .
You may be able to resplice the wires if they are in tact ( but its best done in a speciific way )
A detailed problem description on which wires , the condition of those wire , which gauge(s) and what the year, engine and drive are will help the team in offering good advice.
