electric trolling motor fuse size
jerkoz
have a min-kota 55 lb. thrust bow mount using the supplied wire on the motor. was going to use a 50 amp. breaker. is it ok or maybe to high?
Silvertip
Re: electric trolling motor fuse size
A 55# motor will draw 46 amps worst case which is very close to the 50A. Under normal conditions you would be ok with a 50A since you rarely get the motor to draw 46A. Getting weeds bound up in the motor is one of those conditions. So 50A is marginal and 60A would be preferred. 50A is NOT too high but rather marginally too LOW.
stevecur
50 amp is what Minnkota sells for that motor.
jamoke
60 amp breaker is what my MinnKota Powerdrive manual recommends.
I use a 12v 55 lb model.
