I have a J25ELCNE and I am having problems starting it up. When I initially tried to start the motor nothing happened. I figured that there was either a problem with the wiring, or the starter was bad. I immediately ran a voltmeter over the battery and it read 12V - good.
So I removed the starter from the motor, and disconnected the power and ground cables from it. I used jumper cables to supply power from the battery directly to the starter. I connected the + cable to the power input termonal on the starter. I connected to ground cable to the starter housing. The pinion popped right up and spun like it should. Therefore I ruled out the possibility that the starter was bad.
Then I removed the jumper cables, rewired the starter as intended, and wired the battery into the circuit as intended. With a voltmeter I read the voltage supplied to the starter when it is wired as intended. I connected the + lead of the voltmeter to the starter's power input terminal. I connected the - lead of the voltmeter to the negative terminal on the battery. When I turned the key on the control box the voltmeter read 12V being supplied to the starter.... only it does not do anything?????? In addition, voltage going into the solenoid was 12V. Voltage coming out of the solenoid was 12V. Voltage at the engine ground terminal was 12V.
I was kinda hoping that the internal wiring harness was bad but it appears that maybe it is not???? Looking for expert advice only. Looking for the 'next step' in diagnosing the problem.
Scott
Scott
