Dirtymike20
- Aug 9, 2021
- 33
I got a boat and the lower unit is cracked. But I also have another boat same motor.. same lower unit.
My question is can I just pull the whole drive off the boat? The throttle cables are disconnected already, figured I'd just swap both drives and not mess with lower unit.
Its a v6 3.8l 1984 hammond omc stern drive
Both boats are identical.
Can you just pull the bumpers off and take the bolts where the drive pivots up and down? Then pull it off. It doesn't have a drive spline it has the two gears that mesh together. Like I said the shift cables are already disconnected and pulled through the housing.
