Electric Primer System 40hp Evinrude
Bruner001
I have fuel leaking from around the electric primer. I did not know how to use the RED Lever until I read this forum. The motor was running OK until I took off the BLACK CAP that was on the red lever now I have gas leaking from the primer area and I can't get the motor to start.
Did I break something? Is it leaking because it is flooded? I seems to make no difference what position I put the lever in.
The BLACK CAP covers what looks like an air valve. What is the air valve for?
Please help! I have no books on this motor and the serial number is not readable. The boat is a 94 model so I think the motor is close to a 95.
Cat nip
That valve is similar to the one you would see on a tire. On the engine it is used for testing fuel pressure and adding a cleaner or fogging oil. My guess is that Schrader valve us loose letting fuel by it. They make a tool for it you can find at your auto parts store. Its not supposed to be super tight so just snug it up. If that doesn't work you will need a new primer solenoid. Tight it tight and to tight is broken.
