jdogonhood
- Jun 26, 2011
- 25
Help. I'm trying to wire my new electric fuel pump to the new pressure switch on my 88' 4.3 omc. The safety switch has 3 prongs P, I,S. The fuel pump has two wires. The directions state to attach the red power pump to the P terminal and then ground the black pump to the block. My question is where does the existing light blue wire go from the old oil pressure sending unit ?, and what wires go to the I, and S positions on the pressure switch? It states starter relay and ignition switch. Where do I run these from? Can I just run wire from the starter solenoid? I am electrically challenged so if someone could be very specific I would really appreciate it. Thank you...
