Re: Electric fuel pump replacing VRO?
never do that, there is no method to turn off the pump if the engine stalls. EXTREME fire hazard.
you can use the new, premixed pump designed to replace the VRO ($350) or you can use 2, part 0385784 FUEL PUMP ASSY, inline one is pickup pump, other works as pressure pump. uses pulse line from old vro.
