Hi...
I am wondering if someone would please give me some tech advice on an issue I have on a motor I just purchased?
Motor: Older 70HP Johnson Seahorse. (I think a 1975)
Can not read model number.
Motor starts fine but revs really high.
If I move the choke rod manually, RPM will go down.
When I follow the red wire that is connected to the electric choke, (I think that is what it is) Pic's here: http://sonicinfo.org/boat/ , it goes underneath the dash. I have not got under there yet to see where it is tied in.
One question is... I believe that the red wire is positive but should it be 12v constant or only until the motor warms up or exactly how should this wire be hooked up?
When this wire is hot, if the choke is working, it should control the start up RPM, right?
Any other thoughts?
Thank you for you help,
John
Any other thoughts?
John
