Re: Electric brakes
I can't comment on them as far as for boats. I've never owned a boat that needed brakes on the trailer. I have however done A LOT of towing with other trailers that had brakes.
Electric brakes are FAR SUPERIOR for stopping. The control box in the cab of the truck allows you to set how hard the brakes will activate, and also when they will activate. What I mean is you can adjust the pendulum slightly forward in the controller so the trailer brakes will lead slightly when you press the brake pedal. This is great for control, and helps eliminate wear and tear on the truck brakes as much. Also the brakes on the trailer can be manually activated via a lever on the controller, this is useful for checking the brakes while getting underway, also if you happen to get a bad sway from a poorly loaded trailer a little tap of the trailer brakes will bring it back around behind you straight and true. One last thing, this feature allows you to activate the trailer brakes manually in the even of loss of truck brakes.
How well electronic brakes work depends on a few things like, keeping the plug on the truck clean, and the quality of the brake controller. I would HIGHLY recommend a inertia controller. These controllers most commonly use a pendulum swinging through a electrical gate(think like having a necklace hanging from your mirror). As you apply the truck brakes the pendulum momentum wants to push it forward, thus the harder you hit the truck brakes, the further forward it swings, the unit senses this and applies the trailer brakes proportionately. As you begin to slow, the pendulum begins to come back to center thus the trailer brakes begin to decrease slightly. This allows for a smoother stop.
I would highly recommend this unit, they are more expensive but I have them installed in all my trucks. The Prodigy from Tekonsha. it's also the only unit I know of that allows the trailer brakes to work in reverse.
http://www.campingworld.com/shopping/item/prodigy-brake-control/20535
the other option for controllers are Time Based ones. These simply are timers. They determine when you touch the truck brakes and begins to add trailer brakes to the limit you set in the time you set. This all happens regardless to what your foot is doing with the brake pedal.
Like I said, never used electronic brakes in and around water but I don't see a large problem with doing so. Someone may be able to elaborate more on that. Hope this helps. If you have anymore questions please don't hesitate to ask away.
Bill
