Re: Electric Brakes not working
I don't remember what year GM did it but they changed the convenience connector for installing a brake controller. Unless you bought the truck new do not count on the connector being right. If you bought it used and asked for the convenience connector, the salesman scammed it from another truck, maybe an older truck, betting that the buyer of that truck wouldn't know/care if it was missing. <br />If you are by yourself either block the brake pedal with a stick, snowbrush, or other rod, adjust the "Level" control on the Brake controller and test the output. Also, check the fuses under the hood. They are probably marked Stud #1, and Stud #2, or something similar. Pull one or the other and test again, one should kill the output to the "Brake" contact. If all tests out with the truck check the Ground for the BRAKES on the trailer. Just because the lights work does not mean the brakes have a good solid ground. Also check continuity through the brake circuit on the trailer at the plug, from the plug to the brakes units, etc. If the circuit is open there's your problem. If you pierce the wiring insulation remember to SEAL the wire!
