electric bolster seats not working
allante
97 fountain fever 27'-- electric bolster seats do not work from their switches--Can jump hydraulic pumps from the battery and they both work. Have power at the switches,have continuity from switch to pumps. could both switches go bad simultaneously? cannot find any bad fuses --don't know where to go next--any ideas?<br /><br />thank you
amirm
Re: electric bolster seats not working
Let me understand this. You hook up power directly to the pump and they work. you have power to the switch. And you have checked continuity between the switch and pump and all checks out. Correct?<br /><br />Then try one more thing. Measure the voltage before and after the switch. That would tell you if the switch is working.<br /><br />Amir
