Have a 1997 Merc EFI 175. Problem is sometimes it will plane up and run sometimes it won't(under load). Encounters a serious surge problem. The computer and sensors have been checked. They are OK. If I take the motor out of gear,rev it up to a little over 1500 rpm let it calm down it will plane and reach WOT with no problem so lon as I don't let out of the throttle appears to surge around 3500-4000 RPM push the throttle back up and it goes away. Have checked everything I know by the book(I'm no dummy)Last resort is to clean the injectors and if this doesn't work I'm lost Already drained the fuel and added 2+2 no help Checked fuel Pump out put and it's good. Any help anyone can give would be greatly appreciated. Marine dealer can't figure this one out either. null
