Boomyal
- Aug 16, 2003
- 12,072
Here is the deal. I recently posted regarding water puddles in the opening of my exhaust manifold ports. It did appear to be small puddles in the front six cylinders. This occured uniformly on both sides. After much fretting, questions and pressure testing the mani's, the conclusion was that a small amount of water was reverting from the *ss end of the mani's.
It was also stated that Merc had put out a bulletin that recommended that you run the motor up to fast idle before shutting down, to blow out any water that had come in the back door.
I suppose that that is probably an effective method but I had another idea. What if I installed a ball valve on the line from the impeller to the heat exchanger and shut it off 15 seconds before I killed the motor. Whether on the hose or in the water the impeller would stay wet, albeit deadheaded while the the mani's would go dry, allowing any reverted water to be blown out with the exhaust.
What say y'all?
What say y'all?
