1994 Merc 4.3LX
Weber 4 bbl, divorced choke
New carb: Edelbrock 1409 with the jets/metering rod calibration kit; electric choke.
SO, I'm in the middle of swapping out the Weber for the Edelbrock 1409. Changed the jets and rods, installed the (-) on the choke to the choke mounting screw, brought it out to the boat for the swap and found a couple of oddities...
1) There is no "Choke pull-off", nor anyplace to mount the old one on the new, as that is where the electric choke is on the new.
2) Also not the port on the new carb immediately in front of the fuel inlet. What goes there?
3) I've got a purple with white stripe wire in very close proximity to where the choke will be. Is this the right wire to tap into for power for the choke
Thanks in advance!
Don
Thanks in advance!
Don
