jmeydenbauer
- Sep 21, 2003
- 47
I've got a '77 OMC 235 HP (Ford 351) with an Edlebrock 1409 carb that is stumbling just off of idle. I've followed the tuning procedures listed in the carb manual and just can't get this stumble cleared up, it happens ~ 900-1,200 RPM and runs fine everywhere else. I've tried every combo of .098 and .101 primary jet with metering rods 1447, 1444, 1445, and 1451. I've also tried the orange, blue, and silver step-up springs. I've checked my fuel pressure and it's at 6.5 PSI at idle. The carb is only ~ 1 year old and has always had the problem but I'm just now able to work on it because of other problems that the motor had which are now fixed. I don't have any vaccume leaks that I could find and I've got 16" of vaccume at idle. I've already taken the carb apart and cleaned it out with carb cleaner and compressed air. The carb was still very clean and it didn't make any difference. The ignition has been upgraded to the Pertronix II along with a new coil, plugs, wires, and cap. The timing has been set to 10 deg. BTDC as per the manual. The carb sits on a 1" 4-hole carb spacer with vaccume port<br /><br />The best settings that I've been able to come up with so far are:<br /><br />Primary Main Jet: .101<br />Metering Rod: 1444<br />Secondary Main Jet: .101<br />Accelerator pump: Middle hole<br />Step-Up Spring: Orange<br />A/F screw: 2 ¼ turns out<br /><br />The stumble is a lean condition at that RPM as a shot of staring fluid will cure the stumble and RPM's increase. If I try the shot of starting fluid at an idle, the engine dies (as expected). I am also able to move the point of the stumble up a few hundred RPM's if I adjust the A/F screw out richer than needed at idle.<br /><br />Again, the motor starts great, idles great, and revs great, it just stumbles when slowly increasing the RPM's through that 900-1,200 RPM range. Any ideas?
