QuadManiac
- Jul 2, 2007
- 391
Hey Ritt, that's you selling these on eBay, isn't it?
I finally got around to installing the correct 1441 adapter on my tilt cylinder (you told me about it here, last month, thanks).
Question for you:
Just prior to going out to Lake Mojave/Laughlin for 5 days in July, I noticed that the tilt cylinder was leaking down... maybe 60 seconds from full up till it hit the travel lock. Last day at the lake, when I goosed reverse, the upper fitting on the tilt cylinder (the 1441) grenaded. Finished fixing it yesterday, refilled with fluid, worked it up and down, maybe 10 times. Great!
Now the leakdown seems to have gone away. It sat proudly at the full up position yesterday for at least 10 minutes, before I got bored and went on to other things.
Is this explained by, perhaps, low fluid level prior to the fitting letting go, or a tiny leak in the fitting prior to its total destruction? The top line pushes down, not holds up, so I don't see how that would affect leakdown unless it was allowing air into the system. I didn't see any oil in the area... so I'm wondering if there is any other obvious reason. It certainly seems to have self corrected.
Thanks for your help!
Question for you:
