Re: EATING POINTS
yep djohns19 is dead right, you should have 12 volts going to the points only when cranking to aid starting, you can check this very easy with a volt meter, while cranking the voltage should stay high 12 volts plus, as soon as it starts voltage shoud drop,the ballist resistor is a good part of the plan, but what some times happens is the wrong solenoid gets installed, they look the same but are different 1 is a starter & 1 is a slave if you switch them and use them the wrong way the problem your having shows up, its all in the way there grounded, to much typing to explain. but not a bad idea to check.<br /><br />good luck
