I was testing out my 79 7.5 Merc and all was well till the pee hole went dry. It just stopped working. I dropped the lower end and found my impeller chewed to shreds... What in the world can cause this. My filter was inplace and clean, the Impeller was new last october(just replaced). All I can think that would cause this would be impropper installation. How is the impeller supposed to be inserted into the housing assembly? is it supposed to be tight or very loose? Are the veins to be bent or just touching the housing? Any info, before I put another impeller in would be greatly appreciated. Thanks in advance for your time.
