Recently aquired a mid 1980's vintage mariner 15 Hp that will not idle. It will start and run at the mid to high RPM range, but forget anything that remotely resembles an idle. The carb has been overhauled and the plugs replaced. I have done the bulb test, but have yet to try the WD 40 in the throat test. I have been told that it may be the ignition coil or the condenser charge coil. I get a blue spark when I pull the starter cord, but I would not describe it as impressive. How do I check these coils, or should I look elsewhere first. Thanks in advance for any thoughts or suggestions.<br /><br />Case
