Early 90's Yamaha 15hp won't run at Idle
Arkie1
I have an early to mid 90's Yamaha 15hp 2-stroke that will not run at idle. It will run at 1/2 to full throttle. It will only start at almost full throttle. I have cleaned the carbuerator, thus seemingly eliminating that problem. Could it be the diaphragm? I have changed the gas, so I know it is not bad gas. Both plugs are firing at all throttle positions. I assume that this is a problem in the electrical system. Does anyone know how this system operates, and if so which one of the electrical coils would cause this problem? Is there any way of checking the coils so that I can find the bad one? When I used the boat for duck hunting this winter it was running just fine.<br /><br />Any response would help. Thanks.
