stingertrey
- Sep 30, 2009
- 127
Hey, guys. I havent been on here in ages but this place has always been my go to for issues I cant resolve.
Anyway, I have had an evinrude 20hp for quite a few years and its always ran well. I didnt run it for probably a year and a half. Throw some life in there mixed with deployments and it was neglected. Well... the last month I've replaced the water pump to make it pump, removed the carb and completely went through it. I took it to the river and it ran like a new motor. flash forward 2-3 weeks and I took it back to the river and it would not run well at idle and basically wouldnt go to higher rpm's.. it wouldnt die out it just stayed in a boggy state and wouldnt "take off" just perma bogs. During WOT input I can have the fuel line crimped like you would a water hose and it will TAKE OFF and run.. SO I say ok its flooding (needle valve not seating was my thought) this was all but confirmed when I got home and it sat for 2 hours or so and filled my cylinders with gas.
I took the carb apart and its spotless. float is adjusted to level as it should be.. and the needle valve and seat are both clean and brand new.. So I thought maybe a fluke.. made sure it was all clean by spraying and put it back together... continued trying to fill cylinders with gas if it sat out in the sun, took it to the river this morning and its the same thing.. boggy and only runs well with the fuel line crimped to limit fuel.. its also smoking like hell with a 50:1 mixture which makes me think its extremely rich fuel/air. I bought a new needle and seat on the way home from a boat shop so im probably gonna slap that in there. Is there anything Im missing here?
the only item in the carb that isnt new is the float.. Im going to replace that as well when I go back in. Its not hollow plastic style floats.. its almost foam feeling. but it doesnt seem to be saturating with fuel.. So I let it ride initially
