Re: Ear muffs/cold temp gauge
To me, the only time I am concerned with getting the t-stat to pop open is to ensure I am actually flushing the entire engine after running in muddy, salty or brackish water.
Others try to winterize by running antifreeze into the engine on the muffs, and it is inherently problematic, because there is no guarantee the T-stat is gonna pop open.
Sounds like you are just checking things out... but... having air temps in the 60's is kind of chilly, esp w/ cold house water + cold engine. When I pull my boat out on a 80 degree day after running around all day, if there is a lag time between the ramp and home, it might cool off too much and not get the t-stat to open again -- well, not always, but it just magnifies the reality that cool air, cold water and an ice-cold engine = might not warm up on the muffs.
On your initial sea run this year, watch the temp gauge. She should peak, then drop when the t-stat opens, then level off. That's it.
