Hi, I just did a search on transducer mounting and found lots of good stuff but I still have a couple of questions. I decided to go with the shoot through the hull method, and I like ThomWV's method with th PVC pipe and the mineral oil but the instructions recomend epoxying it directly to the hull. The transducer that came with it is the skimmer kind for the transom mount but the instructions say you can mount it either way. The boat is a new runabout with a solid fiberglass hull. I guess my question is which method works the best. Thanks
