Re: Eagle 480DF Sonar/GPS
John,<br />I'm sure the unit you're describing will be great. I have a Lowrance LCX 15. I really like the larger screen because I run it in split GPS/SONAR mode quite a bit for the type fishing I do. When trolling for summer Walleye I first go through a promising area and waypoint the individual fish or groups of fish. I then troll/fish back over my waypoints and use the sonar to see if they are in the same location. If you plan on using your unit similarly, you would probably really appreciate the larger screen size. <br />JD
