Eagle 168 fishfinder
Batty
Hi,
Bought this new recently and have just installed it on my boat.Screen came up fine at first but now all it will do is beep when I press the power button and shows a darkish blue blank screen. I am in the UK and bought the kit new on e bay, but it was supplied from the USA so I can't really return it if faulty. I am probably doing something wrong but the manual is little is a bit useless on troubleshooting.
Can anyone help?
Thanks
Batty
Silvertip
Re: Eagle 168 fishfinder
Is the boat in the water when you have this issue? If you have the boat out of the water, it may not display anything. Try reducing the "contrast" and "sensitivity" settings.
Batty
Hi Silvertip, Thanks for reply re fishfinder.Problem resolved. I found that I had bent one of the pins in the unit trying to plug in the transponder.
