dyno instead of test wheel
blgrams
how do you determine how much resistance to set when using a dyno to set timing at WOT?<br /><br />how do you determine how much to cut down a prop to make a test wheel?
JB
Re: dyno instead of test wheel
You read the Operator's Manual for the make and model Dyno you are using.<br /><br />A correct test wheel will offer the same torque load as a correct prop. Cutting down a prop wont cut it.<br /><br />Moving to General Outboard (non-repair topics)
