I finally have my powerhead back and installed. New fuel pump membranes, rebuilt carbs, new rings, etc. Its running at idle very well, but going into gear it dies. The idle adjustment screws on the carbs are at the recommended 1-3/4 turns out from lightly seated. I'm running premixed fuel at 25:1 for the break-in period. My timing at ilde is correct at 5-7 deg BTC (this is correct for this year; I know its different for later years).
I'm looking for suggestions. It sounds like a fuel issue-like its just not getting enough to keep the motor going when going into gear. It will die even if I put it into gear and then give it trottle immediately.
I've been through Clams Casino's post about how to set the timing, sync the carbs, etc. It assumes that the motor doesn't die going into gear, which is my problem.
Any thoughts, suggestion etc. would be appreciated.
Thanks,
Jim
Thanks,
Jim
