Re: dumb Question
'Mornin' KiwOn2,<br /><br />Stop at your local auto part storeand pick up a compresion test gauge. They can be had from about $15.00<br /><br />Remove and ground the plugs. Throttle the carbs to wide open. Then, one cylinder at a time, connect the compression gauge to a cylinder and crank the engine a few times until the gauge reading stabelizes.<br /><br />Each cylinder ought to read 100+psi AND more importantly, the cylinders sould read within 10% of each other.<br /><br />Let us know and we'll go from there<br /><br />Good Luck<br />HAVE FUN!
