quick_claude
- Nov 6, 2001
- 16
Just bought a used 19'1979 Chapparrall bowrider with 120hp I/0 (I-drive). I pulled the lower unit to replace bad impeller. Noticed that the bottom oil seal on the upper unit (where the drive gear spline goes into the upper unit)was bad. First Question..do I have to pull out upper unit driven gear assembly (and have to buy the two mercruiser shimming tools) just to replace that one bottom oil seal OR can I replace that seal from the bottom since it is somewhat flexible? Question2...is this boat underpowered? Thanks in advance to everyone for your advice.
