Dumb carb question
JasonB
Do square bore and spread bore have different bong patterns? (I'm sure they do, just conforming here)<br />Reason for asking is I am looking for an original Mercruiser throttle cable bracket for my 4bbl conversion. My square bore Holley has a 5 3/8" distance between the rear bolts. I have found a bracket from a "4bbl", but the owner hasn't measured it yet.
Re: Dumb carb question
Merc. used Both the Spread-bore Rottenchesters,+ the Square-bore Webers.........<br /><br />Ayuh,...... There's a difference to the Bolt Spacing.......<br /><br />
Well,....................................<br />A Bong Does have a Carb. Hole.............<br />But,...... I've Never seen a Bong pattern on a Carb............................................................................. :D
snapperbait
Bong huh?.. <br /><br />Jason musta been hangin' with them reefers down in the cellar.. :D
salty87
bondo, i think you've set a new standard in covering all the bases on that answer.
JasonB
I won't bother fixing my typing error...how in the world did my fingers type "bong" instead of bolt.... I also said conforming instead of confirming, as then everyone else will be wondering where the bong stuff came from :D <br /><br />Typos make the world laugh sometimes.... :p <br /><br />Just for complete-ness to Bondo's list, Merc also used a few square-bore Holley carbs too, at least in the early-mid 70's on Ford engines. <br /><br />I just need a way to attach the throttle cable without spending big $$$ on Holley's support kit.
