Re: dumb a/c question
Texan Ron,<br /><br /> This something that I have been kicking around. Mounting a A/C compressor from a car, use a water cooled condenser(which would be tapped off the waterpump, and returned through the exhaust), and a small air handler. Then use insulated 4" flex duct to route through the cabin.<br /><br />I even thought about using bilge blowers to use for the airhandle blower. This way they would be USCG Approved. However I am not sure about the clutch would be approved since it would be possible for it to throw a spark.<br /><br />Two reasons I have not gone ahead with my plans.<br /><br />1. Knowing the clutch would not be approved.<br />2. Sitting for long periods with the A/C on would lead to premature failure of your drive line, since it is constantly turning. (Unless you have an inboard with a trans)<br /><br />Still without A/C but still scratching the head trying to figure something else out. Good Luck SS
