Re: Dual Station Electronics
Many nmea displays do not allow for multiple networked displays. nmea 2000 displays are however all able to work wit numerous networked devices such as "black box sounders" engine data from nmea compliant engines, gps, radar, all on one display however to share these devices between two or more displays requires some of the high end displays from any brand. I currently own a raymarine c-80 display dsm 300 sounder module 2kw raydome and gps antenna this is not a cheap system and if i want to add an additional display the only shared data is the gps via seatalk cable.
I would suggest you research the product you intend to buy thoroughly before you buy it will save you thousands.
