Dual Prop Question
cortez
Can anybody help me to identify the props that I have?
I need to replace the props on my boat which is a Crownline 250, with a volvo 5.7 dp, engine number 4100145250, outdrive serial number 5102144166.
I should imagine I need possibly B4's or B5's but on taking the old props off, the only number that is shown, is on the larger of the two props and is 7293 quite a large space then 3 on it's own. All the volvo numbers start with 854###.
The dry weight of the boat is 5500 lbs. Can anybody give me any idea of what props I would need or the props that I have?
I have tried ringing Crownline but they are unable to help me.
Crownie2
Re: Dual Prop Question
If you have no luck here, I suggest you try the Crownline Owners Forum, on the Crownline website. Someone there may possibly be able to help you.
Good Luck!
Bob
