vinodubber
- Jan 7, 2012
- 2
After doing everything to try to overcome an overheating 81 Mercruiser 470 including unblock heat exchanger, replace blown heat gasket and machine head, replace impeller and housing, replace intake hoses and the list goes on. Anyway it now stays cool at a bit above idle but gets hotter as the revs increase. I assume this is due to still having the original 3 inch heat exchanger.
I was wondering if I could install another 3 inch exchanger to double the cooling capacity? I would just try the 4 inch but they are very expensive and hard to find in Australia. I was thinking of putting a Y piece on the outlet of the raw water pump and again on the outlet of the exchanger.
Just wondering if anyone has had any experience with this?
