Eric in NC
- Aug 3, 2007
- 17
After 50+ years of sailing, I recently bought a power boat...and I'm still trying to figure out how some of the systems work.
The boat is a Grady White 190 Tournament with a Evinrude 150, which has a 35 amp alternator.
Both batteries are Interstate Marine/RV Cranking Batteries. I was told to start the motor with the Battery Select on "Both" and to run with it on "Both."
The only electrical draw after starting is the VHF, the depth/fishfinder, and the use of the power trim. The depth finder has a voltage gauge and it reads 12.2 or 12.3 all the time. I run the boat about 1.5 hrs/wk.
However, I have been reading some articles that make me wonder if having two crankers is wrong...and if running in the "Both" setting is wrong. Frankly, some of the writers I am reading seem to contradict other writers. Then I read the FAQ post on this forum about dual batteries and that just about fried my brain
So I have a few questions maybe someone here can answer.
First, is it a bad thing to have two crankers instead of a cranker and a deep cycle? Am I gonna run into problems using two crankers?
And, is running with both batteries selected wrong? It seems like it would be the right thing to do.
Sure would appreciate getting some guidance about this.
Thanks.
Thanks.
