imported_wildcat
- Jul 20, 2004
- 74
I purchased a 2004 I/O SeaRay 200 with a 5.0L 260hp MPI/Alpha 1, but it only has one starting battery with an ON/OFF switch. The bilge pump/stereo memory is directly wired to battery with a circuit breaker in-line.<br /><br />I have done much searching of this forum and it appears that I need to add a deep cycle battery (per 18rabbit) for stereo/lights. I have no other onboard accessories.<br /><br />Very easy to just install a new battery with a 1/2/Both/OFF switch. However, it appears that I should also install a West Marine Combiner 150 to charge both batteries.<br /><br />Will it be necessary to reroute wiring from alternator and starter? I would like to keep this installation simple but effective.<br /><br />Also, does everyone agree that the deep cycle battery should be installed. The old timer at West Marine told me to install a dual purpose battery due to my limited accesories that I plan to use. He said the deep cycle is only necessary for refrigerators and multiple high drain accessories. The dual purpose will give me more starting power if necessary and also provide ample accessory power.
