Re: Dual Battery Setup
if i am understanding you correctly you want one battery for starting and another separate battery for accesories. that is the way it should be! the starting battery should be for starting only. just look at the terminals on the battery, the single largest wire on both positive and negative side of the battery are for the motor starting, all the other wires are for the accesories. just connect acc wires to a battery, and connect the starting wires to the other battery. dont connect the two batteries together!
