Dual Battery or Emergency Jump Starter?
riazoo
Hi, I just purchased a boat and was wondering if I should install a dual battery switch and an extra battery setup or should I just go with a portable jump starter unit? Thanks
dingbat
Re: Dual Battery or Emergency Jump Starter?
Portable jump starters require maintenance and I can tell you from past experiences with two of them, they have a tendency to fail at the most inopportune times.
Install the second battery on the boat and be done with it.
fucawi
Banned
go with the dual battery...these jump start boxes have a very low AH capacity compaired to the say 60 AH of your main battery ..by a new battery identical to the original then when the older one starts to fail you can swop them over
Silverbullet555
I'll third the motion.
If you have a jump box, use it UNTIL you install your second battery. I've never had a jump box stay working over long periods of time. Batteries on the other hand have lasted years and years and rarely do they outright fail. Usually you get a warning.
Fed
What boat, what motor, what electrical stuff do you intend to run?
I really like your boat dingbat.
riazoo
Ok, will go with the second battery option. Thanks for clearing it up.
riazoo
Hi Matey, you must have a lot of dingbats down under but up here I got myself a 2001 Bayliner cuddy with a mercruiser 3.0 I/O. I was thinking of using the battery for starting. I was planning on installing a tower with speakers and was worried it may drain it to the point of a no start condition. However if I do the dual, one batt would be for starting and the second for everything else - I think!
Cheers.
fucawi
Banned
another point is you carnt just have the jump box laying around ..if could take to the air in rough conditions or crossing a bar ...so you might as well bolt the second battery down as bother with the jumper....
Fed
I think with your boat size & power usage riazoo an extra battery with a one/both/two/off switch is the way to go, make sure you get a quality switch because they can be prone to failure.
The only maintenance they need is to plug them into a wall wart from time to time and after each usage. Mine is now about 10 years old.
The amp/hour capacity doesn't mean anything when it comes to cranking power.
Maybe that's to do with the quality of the jump box, as I said above mine's on 10 years and still strong.
I've found that not to be the case with modern batteries I even had one drop dead while I was filling the car with gas once,... not even a click out of it when I went to leave.
Are you some sort of jump box hater or something, jump boxes have a place just not in riazoo's boat where two batteries would be better for him.
riazoo search out some of Silvertip's posts for the best advice on connecting & using a dual battery setup.
jgos929
I carry one in my boat as extra insurance.
