Fellow boaters
I connected my spare battery, parallel to the other battery (+ to + and - to -). Now I can run the starter longer.
Questions:
1- Is it bad for regulator (e.g. consuming more current)?
2- What does the voltmeter on dashboard (Bayliner Capri 1990) show? Charging voltage (after regulator voltage=battery voltage)?
3- In the first half an hour of cruise, the dash voltmeter shows 12-13v....but after a while it gets higher and higher, till 16-17v! Is it normal?
4- When the voltmeter is 17v, are my batteries boiling and losing water???
Thanks
nozar
Questions:
Thanks
nozar
