Dual battery Help
joecit
i have a 07 suzuki df115 and want to put a dual battery set up in.One question does the pos starting lead off the motor have the alternator wire built into it,or shall i be looking for a seperate wire so i can connect correctly to the switch.Thanks for any help.
bullbat
Re: Dual battery Help
depending on the setup you want all you have to do is hook the batts up in a series circuit, i.e.- pos to pos, neg to neg
