Re: Dual Batteries setup with VSR
With the standard Off/1/2/Both battery switch, you are only selecting which battery you are using to power everything on the boat, house and engine. If you are at anchor you may select one battery (#1 as an example) to run your lights and other accessories on so you don't run both batteries down, but you can also start the engine off that battery. If you use the #1 battery until it's dead, you can turn the switch to #2 and still start the engine. However, with the switch in the #2 position, you will not charge #1 battery, you have to turn to both to charge both batteries, and if the battery is really dean and you turn it back to #1 the engine could die.
Now the Bluesea switch is completely different. It's like having two on/off switches. When you turn it to ON, you turn a switch on that connects the house battery to the house/accessory panel and a another section of the switch that turns on the switch so the starting battery is turned on for the engine and instrument panel.
Now, when you go out to anchor again, you do nothing to the switch. You can now run down your house battery without touching the starting battery. So you start the engine, the VSR kicks in and starts charging both batteries without you having to do anything with the switches.
There is also a second position for the Bluesea switch that combines them all together should one battery fail, you could run everything off of a single battery. But that position is only for use when there is a problem.
