dual axle
Clay
I have a 8000 lbs boat, do I need two 4000 lbs axles. Or does'nt it work that way
D
DJ
Guest
Re: dual axle
cootie,<br /><br />Not necessarily. You also need to figure in the weight of the trailer and all the extras like; fuel, gear, etc.
Down South
Re: dual axle
djohns is right,<br />You need to figure for extra gear, ect. It's always best to have extra capacity even if you will never use it.
Clay
Re: dual axle
thanks guys. forgot about trailer weight. I'm looking at atleast 10000 lbs then. what I was wondering if two axles double capacity. then would three axles triple capacity
D
DJ
Guest
Re: dual axle
cootie,<br /><br />Sort of. <br /><br />You still have to figure what is the weakest link. The weak link could be: tires, springs, axle, wheels.
Mumblerone
Re: dual axle
Don't forget the tire rating. It will tell you the maximum capacity for the tire. Example: If you have four "D" rated tires that are good for 1750 pounds each...this implies 7000# load maximum. A trailer can't be rated greater than the tires. A samll but important point when replacing tires. ;)
6MISFITZ
Re: dual axle
Check with the tire dealer for exact weights you need. Different sizes in the "D" rage do have different capacities. My D range 225/75/r15 can carry of 2400# each. If D is not enough there is "E" range too. Just make sure the trailer suspension is up to the weight of the load too.
