Dual Axel Trailer Noise -Take off & Stops
111torrance111
I have a dual axel trailer I recently purchase (with a boat) that has a brake system, when I first connected it to my tow vehicle I thought something was loose. When I take off I hear a delayed bang that sounded like my tailer hitch was loose, when I stop I hear the same thing. The guy I bought it from said it's alway done that and he never had any problems, this is my first trailer with a brake system and I suspect something is wrong but don't know what to check. All visable indidcation shows everything is OK. Any thoughts on what to check or do trailers with brake just make this clunky sound when taking off?
Thanks for any advise..
dingbat
Re: Dual Axel Trailer Noise -Take off & Stops
Sounds like the coupler. Could be low on fluid or you have air in the brake lines.
Try manually actuating the coupler to see how much fore and aft play you have it. When my brakes are bleed properly I get maybe a ?? of play before I get solid resistance from the brakes pads.
It could also be the equalizers shifting the weight around on the axle. Check to make sure everything in the equalizing system is in working order. Check the spring bushing while you?re at it.
reelfishin
I had one trailer that would bang on stops and starts if the reverse lockout pin was left in.
You can also get noise from slipper or C hook springs on stops and starts, especially if the trailer isn't hitched level.
ufm82
Master Chief Petty Officer
The noise is most likely the brake actuator moving back and forth. Normally there is a cylinder that cushions that motion. A low fluid level could cause this but you'd have no brake action either. Or the cylinder may need to be replaced if it has failed. When I changed over from electric brakes to surge brakes I found the the initial "clunk" on take-off and the "clunk" on braking wasn't a problem as my actuator incoporates this shock absorber in its design. I get the lag both times but it's soft and smooth. Check fluid levels and check for air as stated.
Also check the lubrication of the rollers in the actuator. If they are stuck or seized they can cause issues.
UFM82
111torrance111
Thanks guys...I'll take a look and see what I need to fix.
Great advice..
Jerry
